Can I do a straight LCD swap?
I have a A1211 and want to remove the screen and re-install same on my A1226. Is this a compatible swap to attempt?
Bu iyi bir soru mu?
İptal Et
Apple's line of MacBook Pro laptops was intended for the professional and power users. The MacBook Pro line includes the MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", and the MacBook Pro 17" Unibody.
İtibar: 11
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz AtınBob Saylor, looks like part number 661-4238. That LCD is compatible with the following:"
MacBook Pro 15.4" 1.83GHz Core Duo (A1150) - Early 2006
MacBook Pro 15.4" 2.0GHz Core Duo (A1150) - Early 2006
MacBook Pro 15.4" 2.0GHz Core Duo (A1150) - Mid 2006
MacBook Pro 15.4" 2.16GHz Core 2 Duo (A1211) - Late 2006
MacBook Pro 15.4" 2.16GHz Core Duo (A1150) - Early 2006
MacBook Pro 15.4" 2.2GHz Core 2 Duo (A1226) - Mid 2007
MacBook Pro 15.4" 2.33GHz Core 2 Duo (A1211) - Late 2006
MacBook Pro 15.4" 2.4GHz Core 2 Duo (A1226) - Mid 2007
MacBook Pro 15.4" 2.4GHz Core 2 Duo (A1260) - Early 2008
MacBook Pro 15.4" 2.5GHz Core 2 Duo (A1260) - Early 2008
MacBook Pro 15.4" 2.6GHz Core 2 Duo (A1226) - Mid 2007
MacBook Pro 15.4" 2.6GHz Core 2 Duo (A1260) - Early 2008
Hope this helps, good luck.
Yorumlar:
Just make sure that the magnet that activate the sleep function when closing the display is located to the same side than your original display otherwise you'll lose that function.
lemerise tarafından
Great information!
Thanks so much.
Bob Saylor tarafından
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 88
