Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Camera not working after drop
Hi there,
I have a customer that dropped his two week old iPhone 6. Screen was broken but housing is still mint because of a good case.
I had ordered a new screen assembly and a new rear camera. Repair went perfectly, it's not my first iPhone 6. But when I powered it up, the camera problem was still the same;
camera app opens up but shows only black image. It is however possible to turn to the front camera.
The flash light isn't working either, that was also the case with iPhone 5 that had faulty cameras.
Any advice? I might advise him to take his phone to the store for warranty. The repair was done without fingerprints and such so they won't notice.
Kind regards,
Renaat
Bu iyi bir soru mu?
Puan 4
6 Yorum
i also have this same issue. Any luck fixing it?
tarafından
Me too I dropped it and it cracked the screen saver I took it off and the front facing camera doesn’t work now
tarafından
My back phone fell out of my pocket, and fell face first and cracked on the up left corner by my camera and when I try to take a picture both front and back camera are black and my flash doesn’t work.
tarafından
The same thing happened with my iPhone 7 and I went to apple got a screen repair and everything was good but I dropped it today and now the front camera works but the rear doesn’t and neither does the flash and I’ve restarted it a bunch of time but it stays the same
tarafından
Help@Robert G
tarafından
1 tane daha yorum göster
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
It's probably the rear camera IC chip needing to be replaced if you already tried replacing the rear camera. I had it done for me once so I know it's possible.
Bu yanıt yardımcı oldu mu?
Puan 5
2 Yorum:
How much will it be to get it replaced?
tarafından
Depends on where you take it to. Probably $60-$80.
tarafından
Yorum Ekle
hope this guide will help you https://support.apple.com/en-us/HT203040
Puan 2
2 Yorum:
I used the link above ‘support’ & switching phone on & off worked!
Thank you :)
tarafından
After seeing a suggestion to turn phone in and off, instead I refreshed my phone by holding the on/off button and the home button at the same time(like a screenshot).
Hold them both down till the screen goes black. Wait about 8 seconds before turning it on.
The camera worked instantly and so did the flashlight!!
tarafından
Yorum Ekle
You believe or not but for the first time when i dropped my phone the camera din't worked util few days after i accidentally dropped it again then i switched on. Unbelievably the camera started to work again
Puan 1
1 Yorum:
How exactly did you drop it ?
tarafından
Yorum Ekle
My brother's Iphone 6 + was dropped on the ground and the front of the screen cracked, and now his backfacing camera wont work at all.
the phone wont even switch to the back camera.
Anyone have any idea why?
Puan 0
Yorum Ekle
Drop it again it worked for me
Puan 0
2 Yorum:
You idiot what if it breaks. Dwn the screen breaks
tarafından
Haha that's funny
tarafından
Yorum Ekle
As if you saw bens answer he’s correct but it might still not work if it’s more damaged just to let you know not trying to be offended.
Puan 0
Yorum Ekle
Yanıtını ekle
RenaatS sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 45
Her zaman: 145,620
