Ana içeriğe geç
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
Swapping CPU between DVI Ti models
Hi
Is it possible to take the 1 GHz CPU out of a DVI Ti and swap it with the CPU in a 667 MHz?
Also other components! Such as the battery, keyboard, optical drive, PRAM Battery etc. I have a mostly working 667 MHz and a mostly working 1 GHz and want to make one fully working machine out of the two! How swappable are the various components in general?
Thanks
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I'm using a 667mhz dvi PB with an 867mhz board installed. Works fine, even put in a superdrive from a 1ghz model. I'm not even sure which display I'm using. As long as they're the PowerBook G4 Titanium DVI 667mhz, 800mhz. 867mhz, or 1000mhz, REPEAT! DVI! models! Not the 667mhz VGA or the 1ghz Aluminum models, they're pretty much interchangeable. Some have a bluetooth module (1ghz), others don't. The screen resolution changes some between them, also. So, generally speaking, the parts are interchangeable, just not ALL. Do your homework.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
It's not possible. However you can swap the 667 DVI with the 800 MHZ motherboard, or the 1 GHz with the 867 motherboard. You can swap battery, DVD drive and RAM memory and keyboard.
Puan 0
Yorum Ekle
Yanıtını ekle
Vishy Moghan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 853
