Ana içeriğe geç
Toy quadcopter with camera, controlled over Wifi by smartphone.
23 Soru Tümünü görüntüle
Soru Kapandı
broken cowl frame on main body of parrot (or other drone)
Good Afternoon;
I just received a drone for Christmas and have only gotten to fly it twice. given its size and shape I have not yet been able to find a suitable storage space for it and so to keep it safe I put it in plain sight on a seldom used easy-chair. well as it turned out someone saw fit to stack something there that applied just enough weight and pressure to crack one of the cowls in 2 places about half way through the foam. I was wondering if there is a safe and light adhesive that may be used to secure it without throwing it off balance or if there is some way of procuring a replacement body without having to buy a whole new drone. Thank You in advance for your assistance.
-Gus
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
sidetracked350, I have NOT repaired any of the little drones :-) but here is a great read about the properties and the repair. Now if that is to much ;-) what I have done in the past to repair any polystyrene is to go to a model builder/kit builder store. Those places have the proper adhesive for your situation. Remember whenever you do a repair on it, you are dealing with nothing else but a styrofoam cup material. So if you are not sure about what to use, do not test it on your drone. Test it on a styrofoam cup, its a lot cheaper. For more glue ideas check on here. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 365
