Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Soru Tümünü görüntüle
Display and touch doesn't work
Hi, i have a problem with my iphone 4 gsm. after a fall the screen went black and it broke. I replaced the display (I've tried 3-4 of them) but the problem is that you see a central oval clearer and the rest black with some lines and halos but no system image. There is something that probably should not be. help me please. thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi, Did you disconnect the battery and make sure the phone was powered off when you replaced the display assembly? I have seen iPhone's not boot up properly or not display anything or display a white screen if the battery was still connected and the phone's power was powered on when the display assembly was connected. Could be the power button was pressed accidentally when the display was disconnected and the battery still was connected to the motherboard. I recommend making sure the phone is powered off before opening. Then disconnect the battery connector from the motherboard when you do the screen replacement? Then disconnect and reconnect the digitizer and LCD screen connecters to the motherboard and make sure they are connected tightly and reconnect the battery and power it on. Hope this helps.
iPhone 4 (GSM/AT&T) Screen Replacement
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
riccardo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 53
