Ana içeriğe geç
The Xiaomi Mi 3 is a high-end, premium Android smartphone that is produced by Xiaomi.
22 Soru Tümünü görüntüle
G-sensor, accelerometer doesn't work?
Hello
I have a problem with gyroscope and accelerometer. It all started when I dropped my phone on the floor, broke the screen and changed it by myself. This problem was fixed, but I had to look inside my phone few times more to change some parts killed during screen change. It was fully functioning for some time(maybe month), but then screen stopped rotating, compass stopped..other words gyroscope and accelerometer died. After some experiments I noticed, that it starts working when my phone is uncovered till the motherboard. But as soon as I cover the motherboard and push on the cover(as screws do) gyroscope stops. Gyroscope chip soldered to the board good(tried to heat it) and the contact on the other side is also good. I can't understand what's happened because gyroscope stops when I push on the connector, so it could be bad contact, but also other problem caused by board deflection, and also gyroscope stops working when I push on the board near the chip(from the other side), once again board deflection or bad contact caused by board deflection. Last time I opened my Mi3 sensor stopped working in any conditions. Please find attached photos of 330DC gyroscope chip and the connector on the other side
If anybody met such problems or has any idea what to do - I kindly ask for help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
2 Yorum
Same problem....waiting for a solution...
tarafından
can't see the "attached photos of 330DC gyroscope chip" Use this guide Adding images to an existing question to add images
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Take apart the motherboard and see if it's warped / bent near the wifi antenna connector. There is a small slot on the frame and the board has to go in there. If you overlook this and screw everything back in place, the forces will warp the board. Happened to me, learned it the hard way :(
The acc/gyro chip (330DC) is in that area. If the board is warped, it may break the solder joints of the chip. You can straighten the board again with pliers, but that didn't fix the solder joints in my case, good luck.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Thanks. It really works. Luckily I had solder joints in place. Used 2 credit cards to flatten the mainboard.
Now all sensors work perfectly.
As the display frame was not original I had to remove some blue thermo conductive plate from the frame, where the processor is placed on, to place the mainboard in a right way.
tarafından
Yorum Ekle
Hi I have the same problem.. After I have replaced mi3 frame, all worked for about one day, and then all the sensors stopped to work.. Have you found any solution to this?
Puan 1
Yorum Ekle
Bad insert mainboard on frame... Make it sure on left part of frame.
Puan 1
Yorum Ekle
Hi, everybody. I have the same problem with my Xiaomi mi3 wcdma. No working sensors. Below the screenshot of sensor box program - https://drive.google.com/file/d/0B0I78qO...
How can I fix it?
Is described here solution - G-sensor, accelerometer doesn't work? - helpfull for anybody? How do you do it? My motherboard is bent near the wifi antenna connector too.(https://drive.google.com/file/d/0B0I78qO...)
Thank you.
Puan 1
Yorum Ekle
I bought a new mi note 3 . A week later I found that my phone cannot detect its actual horizontal or vertical position. Its shows a 3 degree deflation. Now the problem is when I play a racing game, car move to left even if I keep the phone horizontally on a table. Is it possible to correct this deflection myself
Puan 1
Yorum Ekle
Yanıtını ekle
Pavlo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 8,977
