Ana içeriğe geç
LG Optimus G, 19 Eylül 2012 tarihinde duyurulmuştur. LG Electronics tarafından tasarlanıp üretilen bir akıllı telefondur. ABD'de AT&T ve Sprint aracılığıyla temin edilebilir. AT&T, 8 megapiksel kameralı E970 modelini sunarken, Sprint ise 13 megapiksellik LS970 modelini sunmaktadır.
How to get back the IMEI
My LG Optimus G has lost the IMEI after dropping from the chair. The IMEI in My Phone Identity menu said "Unknown" and so did the IMEI SV. The networking is normal, I can access the internet but I cannot have the phone call although the phone has simcard and memory card. My floor is made of ceramic. What can I do to repair my phone.
A repair shop told me that the hardware is the cause, not the software. But they don't have this kind of hardware.
If the hardware is the cause, could you please let me know what is it, what is the product code, eg, so that I can identify it and buy it online.
Thank you,
Bu iyi bir soru mu?
Puan 8
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
It is not a hardware fault. IMEI is a file in root. use imei writing tool and write the original imei.
Try below steps,
In the dialer , type- *#197328640# or *#*#197328640#*#*
>You will be prompt into the Command mode, On the screen provided , Select on Common , normally option 6
> Now Select (FTM) Option 1
>FTM is for debugging and testing .,(Field Test Mode)
>If (FTM) is on, you will have to turn this OFF
>As soon as your turned this off your NULL or altered IMEI number will be restored
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
i have lg MS500 ,showing imei null.
how to change imei no back to original?
Update (08/22/2016)
i tried the above but not working on my phone too.
can any one sujjest what to do?
Puan 1
Yorum Ekle
I lost my phone (LG optimus G pro) and I know it IMEI number of my phone. I want to find my phone is location. please assit me. Thanks
Puan 1
Yorum Ekle
yes this a hardware issue.
Puan 0
Yorum Ekle
this not working on my phone
Puan 0
Yorum Ekle
not working to my LG P970, do I need to insert a SIM card?
Puan 0
Yorum Ekle
My phone is screen lock i have no mobile box how can i see my phone imei model no LG Optimus G E975
Puan 0
Yorum Ekle
I've never heard of something like that happening. Are you able to put in the IMEI manually? The IMEI and other numbers may be written near or under the battery. Have you tried a Factory reset?
Puan 0
Yorum Ekle
Check if your Baseband is not Unknown,restoring IMEI is easy.
If Baseband is Unknown then you will need nvram from working phone (same model).After you get Baseband root your phone and use "MTKdroidTools"
Puan 0
Yorum Ekle
Yanıtını ekle
tin trinh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 25,956
