Ana içeriğe geç
ZTE Boost MAX N9520, 4G LTE ve Android 4.1 ile 5,7 inç HD IPS ekrana sahiptir.
screen touch does not work after replacement?
I replaced the screen and digitizer and the screen comes on but touch doesn't work. I've checked all connections twice. What could it be?
Bu iyi bir soru mu?
Puan 1
3 Yorum
Jeyson......did you end up fixing this problem??
tarafından Paylaş
I have the same issue. My ZTE zmax pro z981 screen broke and I bought 2 new screens and after I put new screen it lights up but doesnt respond to any commands
tarafından Paylaş
I have the same problem except mine's a ZTE n9521 screen not responding to touch
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
jeyson, if you are sure that all your connections are properly seated, I would contact the vendor and replace the assembly once more. Sadly enough, it is not uncommon to receive a bad digitizer. Of course, you always want to double check your work, check to make sure that there are no bend or broken pins on the connector.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
jeyson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 1,633
