white screen on tv
white is to bright to see picture? turn it off and back on picture came back on.Then does it again after a minute or so.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 8,757
wardharold, first what is your TV's model? then explain the "white to bright" a bit more. Does your TV turn white, as in only the backlight is on or can you still make other things out on the screen. The better you describe the symptoms, the greater the chance to get a good answer. Remember we can not see what you see, so we can only go by what you tell us.
oldturkey03 tarafından
sorry,yes you can see picture,but it`s like you turned brightness up 200%
wardharold tarafından
vizio vw46l fhdtv10a is md #
The VW46LFHDTV10A has an issue with a variable resistor to come of the board. Of course, you want to check all the connections, pay particular attention to the T-con board connectors.
2 tane daha yorum göster
