Ana içeriğe geç
Guitar Hero video oyunu serisinin Guitar Hero III oyunu için gitar şeklindeki kontrolcü.
Broken Connection - blinking lights
Hi Fellas,
up to now my Guitar worked fine. Just today as I tried to connect it seems to connect as Controller No. 2 but the other lights keep flashing and nothing works.
USB connector is unlikely because my other Guitar connects fine and the Broken one doesn't work with my Second connector as well. So I assume the Receiver of the Guitar.
My Problem is now I found no hint where to look for the Receiver Inside the Guitar. Do you have any Info for me about that?
Thx in Advance.
Bye,
Ferdinand
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
1 Yorum
Ive also had this problem and replaced the 220uF @10v capacitor but it still does not work
tarafından Paylaş
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I had the same issue. Controller used to work fine, but after a few years I discovered it wouldn't synch. I tried my other guitar with the USB dongle and that synced, so I knew it was the guitar. I replaced the 220uF @10v capacitor on the main circuit board and it fixed the problem.
Probably a good idea to also replace the 47uF @10v too, since the factory components are poor quality.
Bu yanıt yardımcı oldu mu?
Puan 3
5 Yorum:
I replaced the capacitor and the problem persists. Any ideas?
tarafından Paylaş
The 220uF capacitor change worked for me. Previously, the LEDs blinked in sequence but never synced to the dongle, but now fixed once capacitor was replaced. Thanks.
tarafından Paylaş
It's the correct fix done a few with same issue.. If it's not worked check soldering or polarity or replacement capacitors...
tarafından Paylaş
Great! Just replacing the 220 one did the job here! Thanks!
tarafından Paylaş
For any chance do you guys have a photo of where the 220 uF 10v capacitor is located ?
tarafından Paylaş
Yorum Ekle
Worked for me: http://www.fixya.com/support/t1232769-it...
Puan 1
Yorum Ekle
Hey Ferdinand,
i got the exact same problem.
Do you have any new information or solutions?
Regards,
Henning
Puan 0
Yorum Ekle
i’m having this problem where it flickers irregularly. it’s happening on 2 guitars, 2 sets of batteries, both when the receiver is connected directly to the PS3 as well as PC (no hubs). sadly, i don’t know where my other receiver is.
here’s what it looks like: Guitar Hero 3 controller glitching / random flickering - YouTube
any idea the likelihood of it being the receiver?
Puan 0
1 Yorum:
More than likely be capacitors in the guitars they are known to fail giving the exact symptom you describe
tarafından Paylaş
Yorum Ekle
Capacitors on the les paul gibson model suck jus got one the other day and has this syncing problem what makes this even worse are the screws #0 square like are we serious 🤣
Puan 0
Yorum Ekle
Yanıtını ekle
Gardovan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 118
Her zaman: 44,820
