Ana içeriğe geç
Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20008 Soru Tümünü görüntüle
MacBook Pro 2010 Mid 15" 1333Mhz 8G RAM Upgrade?
Hi all,
I had a 2nd MacBook Pro 2010 Mid 15" with i7, 4G Ram (It is a 1333Mhz, and using 1 Bank, so I still one bank RAM slot is empty right now).
I had search Google before, and look like this model work with 1066MHz only, but I am not too sure. Since new on this.
I want to buy other 4G Ram then install it to the empty slot.. But now, all 4G Ram is 1333Mhz, can't find the 1066MHz Ram anymore on 1st Market ...
Do anyone using this model who success install two 1333MHz 4G ram running on it?
I am using OS X 10.9.5 and OS X 10.10.2 with dual boot on it..
Thank you.
Best Regards,
Jimmy Chan
My web site
My blog
Bu iyi bir soru mu?
Puan 1
1 Yorum
ABCellars,
Thank you. I had using my old T420s's 1333MHz 4G install on my MacBook Pro 15" 2010 Mid.
It work with two 1333MHz 8GB now (Two different brand RAM together)
Thank you.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It has been known to work most of the time, sometimes not. However, putting faster memory sticks in won't buy you better performance. You are limited by the clock speed of the front side bus and memory controller. You are restricted by the design the engineers originally intended the limits to be.
Match the existing stick of RAM and you should be fine.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It doesn’t work on 1333mhz and wouldnt make any real performance difference. Ive had a laptop that i was able to turn on with 1333mhz after fitting but then wouldn’t cold boot the next morning.
Puan 0
Yorum Ekle
Yanıtını ekle
Jimmy Chan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 651
