Ana içeriğe geç
Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
What is the function of this part/wire?
Hello everyone! I had a stripped screw on my Macbook retina 13 inch, late 2013 model that was holding down the metal door that is located on both sides of the hinges of the screen. I had to resort to using a Dremel (rotary tool) to cut a slot on the screw for me to extract it. However, during the process, I damaged this item (highlighted by the orange circle in each image). It was cut near the corner just barely, such that the inner "copper(?)" is just barely visible.
My question is, what is the function of this particular wire/part? Is it a removeable part, or a part of the motherboard aka. really expensive to replace?
The computer is working fine now, but I am slightly paranoid it may cause future hardware problems that will interfere with my work.
Thank you!
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
That's the keyboard backlight cable. Does your keyboard still has backlighting? You need to have low ambient light to see it..
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
It seems as though the keyboard backlighting is in working order! Thank you for your help!
P.S. Is this cable removable from the keyboard?
tarafından
Not unless you remove the whole backlight sheet from underneath the keyboard. Why?
And if your question is answered, kindly mark the answer as accepted to "close the case."
tarafından
That was the second question that I had initially posted, and because it has now been answered, I will accept the answer to "close the case."
Thanks for your help! :)
tarafından
Also to answer your question of why: I wanted to make sure that, if in the case that only the cable is replaceable, and if my keyboard backlighting does in fact act up in the future, I can replace it without much hassle. But because it seems like its not, I've concluded that this is not an option for me. Reassurance, if you will ^^
tarafından
You can replace the backlight following this guide. It's a PIA specially because of the glued batteries, but feasible if need be. Once you reach the last step, you need to peel off the backlight sheet and install a new one. Of course, every time you gut a MacBook Pro like this, you risk damaging components and parts, specially if you like to dismantle it using a Dremel tool instead of good'ol screwdrivers. So don't start on any expensive machine like that unless you're going to be gentle and very patient. And never force it. If it needs force, then something is wrong: stop and re-evaluate.
tarafından
Yorum Ekle
Yanıtını ekle
isyogwki sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 161
