Ana içeriğe geç
Repair and disassembly guides for garage door openers.
16 Soru Tümünü görüntüle
remote opener works close up - but no range
T/S progress so far:
New battery and several different remote control - same result
- can control with wall switch but remote more than two feet away does not work - works within one to two feet.
- suspect receiver circuit in opener - maybe front end not working.
can't find schematics to get in deeper and replace failed component. Any help appreciated.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check your drive unit (on the ceiling). See if there is a small wire hanging down from it. That is the receiver's antenna. If the wire is there, be sure it is attached. Some models don't have an exposed antenna. http://ep.yimg.com/ty/cdn/linear-access-...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
patrickmoretti sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 198
