Ana içeriğe geç
Ekim 2011'de piyasaya sürülen, HTC Pico olarak da bilinen bir HTC akıllı telefon.
Mother Board IS Dead
My HTC Explorer fell down from bike, i went to htc care they said my cell needed to replace motherboard, which cost Rs.6500.. phone's present value is 2500-3000 RS. so why should i give 6500 RS... I JUST WANT MY DATA...? ANY HELP FROM YOU ?
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
tushar, this will depend on what is broken on the board. The only way to get your data back is by trying a repair. Even if you would replace the board, you will not get your data back. It is stored on the original board.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
thank you... so can you please help me how to repair ??
tarafından
Have you taken a look at the board to check for any visual damage. Anything broken off or any components missing?
tarafından
screen is creck please repair the phone
tarafından
Yorum Ekle
Hi tushar
it seems to be motherboard physically damaged. try to power up the phone with powersupply and connect it to pc via usb cable. if the taken power 10mA to 900mA can assume power part is working, if you already debuging mode on the device try to get data via pc. even if you cannot see anyting on the phone display PC may communicate with PC
Puan 1
4 Yorum:
even technician said that motherboard is not working...
how to connect it with PC as cell is not even charging...
and screen is off too...
tarafından
charge the cell using extranal charger and connect the device to pc and check wheater device detected or not
tarafından
Bro, motherboard is dead...
phone is not working anyhow...
tarafından
Oops! Try to find a good condition motherboard from eBay only if you loving to HTC exp
Advice: don’t trust the technician and all the things which they said. Better to find your own way to fix the fault.
if you do right thing your fault may solve
if you do wrong things you will have a good lesson
Cheers!
tarafından
Yorum Ekle
Yanıtını ekle
tushar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 1,096
