Ana içeriğe geç
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 Soru Tümünü görüntüle
Steam wand leaking. Not enough pressure for a good shot!
I'm not able to fully close down the steam wand. So, when the machine builds pressure to steam milk - or to pull a shot - the steam wand leaks and releases pressure. My machine is only a couple of years old, but this problem has been getting worse to the point that it's nearly unusable. The espresso I can make with this problem ranges from so-so to undrinkable.
Bu iyi bir soru mu?
Puan 7
1 Yorum
I have had the exact same problem and experience as Tanya - that is, leaking steam wand couple times over the years. Tech support walked me through the fix it in the past, but they no longer support. Henry H's brief response was enough to remind and motivate me, so I'm going to give it a try later this AM after machine cools down.
tarafından
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
You may just need to adjust the stop on the steam valve; you need to take the top off of the machine to expose it, then loosen a hex-head bolt, tighten the valve then re-tighten the stopper. This may be preventing the valve from turning far enough to close. You may also have some calcium build-up on the face of the valve piston which is preventing it from sealing properly; a descaling (with citric acid) should help.
Bu yanıt yardımcı oldu mu?
Puan 15
6 Yorum:
Take the top off, help please
tarafından
sorted, picked it up for £45 was told it had a leak when using the steam part, opened it up to find the pipe had just come off, easy, the best £45 I've ever spent, happy days,with amazing coffee.
tarafından
Thank you so much for this easy fix. I was losing water and patience. Both are in check now.
tarafından
Bless you, kind Sir. This is the second time I've been saved by these instructions
tarafından
Thanks. First had to do this after about 7-8 years, now about every 2-3 years. Not a big deal. I've tightened this 4 or 5 times now. Glad I bookmarked your comment the first time, as I always have to com back to it to remind me what to do.
tarafından
1 tane daha yorum göster
Yorum Ekle
If the steam wand is leaking the valve o-rings are worn out. To replace the o-rings do the following:
1. Turn off the machine, unplug it, and allow any built up pressure to dissipate.
2. Remove the top cover by loosening the Phillips head screws.
3. Locate the steam handle hex screw on top of the black handle and loosen the screw, 5/64ths Allen wrench, I think. No need to completely remove it.
4. Rotate the handle and valve shaft out of the valve and out through the valve opening in the Barista. The valve shaft has two o-rings in grooves about 1/2 inch back from its end.
5. Take the valve shaft to your local hardware store and ask for replacement o-rings. They are 5/16x3/16x1/16. If you are nice the clerk might remove the old ones and replace them with the new ones. Allow them, removing and installing those o-rings is the hardest part of this job. Rub some hygenic silicon grease on the installed o-rings.
6. Reverse the above for assembly
7. Voila, you are ready to turn on your machine and have a coffee.
Puan 5
1 Yorum:
This is incorrect; the two o-rings on the valve stem prevent water from leaking from the valve body itself. If the wand is leaking you either need to adjust the valve or replace the white silicone disc on the end of the valve stem.
tarafından
Yorum Ekle
This is one of the main problems with home espresso machines. They all literally only last a few years, five at best i've heard. The problem with yours is probably a blown seal, much like an o-ring, some where in the wand connection. If you can dis-assemble the device, voiding any remaining warranty by the way, you can try to just clean the o-ring area and it may become usable for another year at the most. Contact the vendor if possible for an OEM replacement o-ring so that it matches in size and thickness correctly.
Puan 1
1 Yorum:
If the o-rings on the steam valve were bad then he'd have steam/water leaking out near the knob; this would not prevent the valve from closing all the way.
tarafından
Yorum Ekle
For other folks, if none of these solutions work... Our Saeco Aroma was leaking too and I found a different answer online at http://pilkin.com/how/saeco/. The brass valve pin that makes the seal had some grooves worn in from daily use. After sanding those away, back to a smooth finish, the valve seats tightly and the leaking stopped. That'll likely be a necessary task every few years until the unit really breaks down.
Puan 1
2 Yorum:
That's a good tip but not relevant to this discussion I'm afraid; the Barista and Aroma models have different styles of steam valves.
tarafından
I used this for my AROMA model. Worked Perfectly! Great tip. Thanks
tarafından
Yorum Ekle
It could also be leaking because of limestone. Have you tried to decalcify?
Puan 0
Yorum Ekle
I have this same Starbucks Barista machine and have fixed the leaking steam wand problem twice over the ten years that my machine has been operating. At the time that I had my problems (3 and 7 years ago), Starbucks used to provide over-the-phone assistance (even beyond the warranty period) to adjust the machine. You would open up the machine from the back and they would wait on the line to tell you what to do next. There were no parts needed, just an adjustment to the steam wand valve. Unfortunately, Starbucks does not provide this service any longer, and I don't remember exactly what we did... Sorry!
I am now faced with a boiler problem on my machine. Perhaps it is time to get a new one!
Good luck!
Puan 0
Yorum Ekle
You can adjust the black cam with a small allen wrench in the hole to make sure the metal switch isn't touched when knob is in off position, or so the flat side (not the curved side) of the cam is facing the switch
when knob is in the off position.
Puan 0
Yorum Ekle
Yanıtını ekle
Mark Allen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 75
Son 30 gün: 377
Her zaman: 107,270
