Why wi-fi,bluetooth and radio does not work on my phone?
Wi-fi,bluetooth and radio does not work on my phone. How can I fix it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If you have a custom rom, try flashing another kernel. And if stock rom, reflash it again with flashtool program.
Bu yanıt yardımcı oldu mu?
Can you recommend me good flashtool program?
Here is flashtool for all Xperia devices: http://www.flashtool.net/index.php
Completely changed the firmware and flash the kernel. The problem remained. I had stock flashing, now i put Cyanogenmod 10.2. May it be possible to replace the component which is responsible for these functions?
I think you have hardware problem, not software. You may got to your local service center and investigate this issue.
Wifi, bluetooth, ant+ and likely radio as well are all handled by a single chip: Texas Instrument WL1271, so all of them failing together likely means this chip is somehow faulty on your Ray (and mine too).
In my case, watching android system log (adb logcat), I could spot wifi driver errors (checsum errors, timeouts) when trying to enable it, which further indicates some communication problem between the cpu and that chip. Accessing the main PCB, I could see nothing wrong, but there are large RF-shielded areas very difficult to reach without risking to ruin the rest of the board.
Just for completeness, others symptoms in my case are:
I suspect the freeze-on-suspend come from the wlan/bluetooth/... (likely bluetooth) driver trying to send suspend order to the chip, and never getting a response. Trying to enable bluetooth gets the driver stuck in some other place, where it won't take the kernel with it on suspend...
Also, complete suspend does not happen when plugged on USB (likely an intentional feature, to keep providing USB services).
It all started after I let the phone fall (from around 1.5 meter on a carpeted floor), so I suspect some solder broke under that chip.
Sadly, I see no easy fix (reflow ?).
I had the same problem with my sony xperia ZL. Both wifi and Bluetooth have no sign of life, I tried to reset to factory default and change the firmware but not resolved. With the help of Vincent Pelletier answer, I followed this wifi and bluetooth chip.
The board had many probable chips protected by the metal shield. Luckily for me it was the most isolated and the easiest of them.
I removed the cap metal. Thinking it might be a reflow problem as said, I put a piece of paper in order to press the chip against the plate and then put this part of the plate on top of a clothes iron on maximum power for a few minutes.
Scheme used to make the iron in a horizontal position.
Only the part of the chip on iron.
This was possible because the part of the plate under the chip does not have any component.
This solves the problem.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 10,786
2 Yorum
in my case my phone is panasonic p55 and whenever i try to take wifi then the wifi icon blinks and nothing happen
rishav singh tarafından
I am using micromax q424
In this phone WiFi,Bluetooth and hotspot is not working
How can I solve this
Plz help me
Thanks in advance
Roman Empire tarafından
