Ana içeriğe geç
Acer'ın Iconia Tab B1 ailesinin ilk tableti olan Acer Iconia Tab B1-A71, Ocak 2013'te duyuruldu.
How to replace charging port?
Im attempting a charging port replacement on the tablet, i've got the old charging port off without any issues however I can't get the mounting holes free from solder to fit the new charging port in.
Could anyone advise on what I could try, tried solder wick but doesn't help much as I can't get enough heat into the solder between the holes
Resim
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Position the new port with its feet in place, then heat the area (I used a heat gun carefully) while applying a little bit of pressure with a pair of tweezers.
The solder (or whatever it is) will soften with the heat and the port will sink in. Remember to remove the yellow tape from the topside first!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
EvansITLtd sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 2,339
