Ana içeriğe geç
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
CPU is 70 C and fan in lower left corner is noisy
The fan in the left hand corner of my iMac is very noisy almost as soon as I boot up, and stays noisy all of the time. The temperature of the CPU is around 79 degrees Centigrade. I think that's very hot, as the limit is 85. Could it be that the CPU fan isn't working properly? Should I lubricate it/clean it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I would definitely suggest you open the machine and have fun with the compressed air can. It can be either that ur fan is congested and therefore not cooling properly or it can be on its last leg and ready to go. If your at 79C while idle, thats not good. Unless youre running some intensive CPU and GPU programs you shouldnt be at that temperature. If the cleaning doesn't yield results, then I would replace the fan. Heat is electronics worst enemy, so until you figure this out, try to keep the use of the machine to a minimum.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
+ agreed
tarafından
tarafından
Yorum Ekle
Yanıtını ekle
Deborah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,310
