Ana içeriğe geç
Sumvision Cyclone Micro Media Player offers support for USB storage devices and MMC/SD/MS/SDHC cards.
1 Soru Tümünü görüntüle
How to tear down so as to repair?
Hi,
The AV Port pin hole, Power Port and digital coaxial port to the Cyclone somehow pushed way inside and I cannot connect any cables to it. I don't see any screws on the Player.
How do I disassemble the unit to fix the problem?
Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You need to pull of one of the plastic end plates and then the circuit board will slide out. If you have short fingernails you can grab onto the corners and just pull. Alternatively use a thin screwdriver to lever it open at the corners. Please see the attached picture.
However, this is a very complex double board assembled by a robot and is very difficult to repair. You can try to solder back the AV connector. If you do not succeed then you will need to buy a new device.
Kind regards
Chris
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Shiru sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 314
