Bulb startup continuously resets, TV wont stay on
I have a Samsung HL56A650C1FXZA DLP tv. It is about 7 years old. Two days ago, it wouldnt get past the bulb LED light cycle. It began to endlessly cycle the bulb startup process. I purchased and installed a new bulb, which worked for about 30 seconds, started up, had a picture, then began resetting endlessly again. I had a picture, so I know the color wheel is working. The door switch is working, as the LED lights up correctly when I had the cover off. At this point, I am guesing it is the ballast, as thats the only part left thats replaceable for the power process. I hear the ballast power up, I see the bulb light up, I'll get picture for a moment, then it goes i to endless reset. Please help.
Bu iyi bir soru mu?
4 Yorum
My television is doing the same thing. It starts up, the bulb lights up, the picture comes on briefly, then it clicks goes black and the red standby light comes on and then it cycles through again. The only way to get it to stop is to unplug it.
stryker tarafından
I checked the capacitors and they are fine. I believe I have the issue narrowed down to the light ballast.
stryker tarafından
Did this fix your tv. Ours did this some about 1 1/2 years ago and bulb was going out because the picture was very dark. We replaced the bulb and it's been working fine. I turned it off last night and today it comes on for about a minuet then cuts off.
sheila tarafından
Mine is doing a similar thing. If I hold the power cable up it comes back on. Changed power lead thinking it may be that, but again it switches on and off by itself. ??
Murphy 16 tarafından
