Ana içeriğe geç
MacBook Pro models with a 15" display
8255 Soru Tümünü görüntüle
Put used board in and still no backlight
Any help?
MacBook Pro 5.1 unibody late 2008 , 1286
Purchased a used logic board and all works except backlight on lcd screen.
Person who sold board said this board came from a MacBook Pro 5.1 820-2330-a logic board, number is the same as mine.
Still no back light, also my old board did not have an inverter attached, but he says his did. Could this be the reason for the lcd not working
Any help would be great!
Roger
Old turkey here are the photos of the two different logic boards I was talking about. But these logic boards have the same part number 823-2330-A. Please note on one board the connector in the middle, what is it for? Perhaps the cable for the inverter? Thanks! Roger
Bu iyi bir soru mu?
Puan 1
1 Yorum
Sorry I'am trying to learn how to post the photos!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Roger, yes absolutely. If the board that you replaced used an inverter, it is a different board. You will need a board that has the LED driver circuit on it. Those boards are not interchangeable.
Bu yanıt yardımcı oldu mu?
Puan 1
9 Yorum:
Thanks old turkey I appreciate the help. I will send this one back and try to get another one that matches correctly!
Roger
tarafından
Old turkey,
Would you happen to have a photo of a logic board 820-2330-A that shows the connection for where the inverter cable attaches?
Thanks,
Roger
tarafından
The only 820-2330-A I have is the one with the LED driver. No connection for an inverter. Have you checked the 820-XXXX number on the board that you have? Make sure it is the right board. You could post an image of your boards so we can check it with you.
tarafından
Ok I will post photo of my board!
tarafından
Both boards have the same number 820-2330-A. But one board is for a MacBook Pro with inverter for the screen. I will post both boards so you can see! There is an unused connection port in the middle of the board on the used one , it is that port that baffles me. I think it has something to do with the inverter cable, but I would need to see one to make sure. Anyhow, this board wont work for me. Any suggestions on getting a reasonable used board somewhere?
tarafından
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Roger sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 167
