jammed the padlock on my security gate. How do I fix it?
Some foreign things were put in my padlock. We remove most, the key goes in, but can't open it.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Try spraying WD40 into the lock and/or try can'ed air. Either one should flush out any small pieces still inside the key slot.
Did someone put something into the hasp part of the lock?
Are you sure you have the correct key?
If either of these are true you may end up needing a locksmith or a bolt cutter.
Bu yanıt yardımcı oldu mu?
Go onto eBay, Amazon, or just search Google to get a set of broken key removers. They are relatively cheap. (Under 5$) they come with a lot of different jigs and sawtooth picks. Good for getting almost anything out.
It is locked can not open.
have also drilled a hole through lock.
@Antonio Pistritto cut the hasp. Bolt cutters, angle grinder, Dremel with cutoff wheel.
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 2,376
