Will battery from Early-2015 work in Mid-2014?
Hello,
I was just wondering if the batter from the Early-2015 MacBook Pro Retina 13" would fit the Mid-2014 model in order to extend its battery life?
Bu iyi bir soru mu?
Hello,
Bu iyi bir soru mu?
The amount of difference between the batteries is not worth the amount of work and cost - Save your money.
I should point out the real difference is how the newer system manage having more run time is the logic improvements needing less power not the slight battery improvement.
Bu yanıt yardımcı oldu mu?
Hey Dan ! Is it the same connector though ? I need to troubleshoot an early 2015 battery. Can I safely plug a mid 2014 battery in an early 2015 logic board? Thanks a lot !!
They have very different P/N's:
MacBook Pro 13" Retina (2015) link to IFIXIT Battery
* Specs: A1582 - 11.42v 74.9Wh - 6559mAh
* Apple P/N's: 661-02361, 020-00009
MacBook Pro 13" Retina (2014) link to IFIXIT Battery
* Specs: A1493 / A1502 - 11.34v 71.8Wh - 6330mAh
* Apple P/N's: 661-8154, 020-8146, 020-8147, 6712-6700
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 760
