Ana içeriğe geç
Super Nintendo Entertainment System (SNES) veya kısaca Super Nintendo, Nintendo tarafından 1990 yılında piyasaya sürülen 16 bitlik bir oyun konsoludur. Super Nintendo, döneminin en çok satan cihazlarından biriydi ve günümüzde hâlâ büyük bir hayran kitlesine sahiptir.
Every button pauses the game!
Ive tried several controllers on my super nintendo and every game all the buttons pause the game. up, down, left, right, a, b, everything pauses the game. it is the console, how do i fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum:
I have the same exact problem. It can't be that uncommon but I have not found an answer.
tarafından
Hi, I'm having g the same issue, it's 100% not the controller ports as I've swapped them out with a mates and same issue persists. player 2 is unaffected.
I'm going to look at the motherboard later last I'm running out of ideas, hoping it's something simple like dirty trace or capacitor gone.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Your controller port is busted. Check the pins they may be corroded. Try to clean the pins first with rubbing alcohol or compressed air. If that does not work you will need to replace the controller ports and pins.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I tried swapping the controller port as well and it didn’t work. Did anyone find a fix for this yet?
tarafından
Yorum Ekle
That's usually caused by the flat cable that goes from the controller board to the motherboard. All you have to do is either replace it or remove it and solder wires for each trace instead. Some good old cleaning with some IPA will sometimes be enough tho.
Puan 0
Yorum Ekle
What you should do is Open it up. Clean the contacts with some isopropyl alcohol. And it should work !
Puan 0
Yorum Ekle
Yanıtını ekle
SimonFett sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 22
Her zaman: 3,494
