Ana içeriğe geç
A budget companion phone for the Galaxy SIII, Also known as Samsung I8190 Galaxy S3 mini, Samsung Galaxy S III more. Available as Samsung I8190N Galaxy S III mini with NFC. Identifiable by the model number GT-i8190.
44 Soru Tümünü görüntüle
The phone doesnot work any more why?
the battery is full . I pressed the power button but in vain . I cannot enter on the dowenload mode to setup a new room . the problem began when i wiped the cache and set up Stock_QS_Kernel_for_v7.zip
thehttps://app.box.com/s/py3omw2ixlf2chlcqn...
after pressing reboot the phone died .
please help me .
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I've seen people use a micro usb module known as a jig which is able to boot the phone into download mode. If you can find one for your device (I've seen them online at many sites) they are used like this:
Turn off your phone and pull out the battery.
Put the battery back and don’t turn it on.
Plug the module into the micro USB port on the phone.
After about 2 seconds, you can see the yellow download mode logo on the screen.
Unplug the module.
Connect your phone with USB cable to computer and then flash your phone via the program “odin”.
Its the easiest method I know of and the jig is usually pretty cheap.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
ahmedhafezziza sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 266
