(frozen)water in bottom of kennmore 57362 freezer compartment
i am finding (frozen) water in the bottom of my freezer compartment under bottom drawer kennmore model57362 unit is 7 years old
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Clogged or Freezing Defrost Drain
If the refrigerator has defrost drain problems it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment. Thaw any ice that is clogging the drain and make sure the drain is clear consider using an aftermarket drain heater to help prevent freezing of the drain in the future.
Drain Strap
If the defrost drain freezes the drain strap may have fallen off or deteriorated. Although not common, some refrigerators are designed to have a small copper or aluminum strap which is attached to the defrost heater and extends partway down into the defrost drain. When the defrost heater turns on, some heat is conducted through the strap in order to melt away any ice that may have built up in the defrost drain. The drain strap should be in place to prevent the drain from freezing.
Drain Heater
For refrigerator defrost drain problems check the drain heater to make sure it's working properly. If the drain heater is burned out or has come out of place the drain tube might freeze over.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 181
