Ana içeriğe geç
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
20 Soru Tümünü görüntüle
broke the power button flex cable
hi,
i snapped the thin flex cable for the power button when trying to replace the screen. is there a part i can replace? or will soldering work?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
1 Yorum
I have this same issue. I have ordered a replacement cable. Does it require soldering or will it just clip into place?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Soldering skills of medium level will be required and a good iron with small tip (silver bearing (preferred) solder with good non acid flux as well). I would not advise anyone who does not have those skills to attempt repair unless you don't mind F@i& up the whole board. The ribbon can be bought online but it does require soldering.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
oneplus one power flex cable
http://www.aliexpress.com/store/product/...
Puan 1
Yorum Ekle
I did the same thing so I would be interested if you found a workaround
Puan 0
Yorum Ekle
Yanıtını ekle
Damon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 2,702
