Ana içeriğe geç
Released September 2013, the Visual Land Prestige Pro 7D model number ME-7D-8GB is an affordable and sturdy tablet designed for kids.
26 Soru Tümünü görüntüle
freezing up when turned on
Freezing up when turned on doesn't get past the visual land bring the world home and jelly beans page. I tried the reset button. how do I get my tablet back on?
Bu iyi bir soru mu?
Puan 26
1 Yorum
What do I do after factory reset,because it still don't work right
tarafından
Yorum Ekle
8 Cevap
Filtre ölçütü:
Seçilen Çözüm
I had this problem, and the only solution I could find was to hard reset the tablet back to original settings.
It helps if your tablet is completely charged before starting this process.
1. Make sure it's off. (If it's anything like mine was, you may have to press and hold the power button for about 10 seconds until the screen goes black, then connect power (either USB or power cord) until you see the battery charging image... then disconnect power and continue).
2. Press and hold the power button and the volume + button. (Again, about 10 seconds)
- When you see the "visual land" screen, you can let go of the buttons.
- Now you should see a picture of the android on its back with a front panel open, and an exclamation triangle.
3. Press power, and while holding power, press the volume + button again once and release both buttons.
- Now you should see "Android system recovery" text on the screen with instructions to follow.
4. Use the volume down/up buttons to navigate through the menu. If you've made a backup before, scroll down to that option, or you may have to "wipe data/factory reset".
(This is as far as I could go, since my volume down button is broken... but hopefully this will help you move forward.)
Bu yanıt yardımcı oldu mu?
Puan 11
4 Yorum:
Every time I get to it saying visual land it turns all white
tarafından
visual land prestige 10 - after power on, jelly bean displays , then blinking ANDROID is displayed and then hangs up. I bring up the reset options menu but volume down will not toggle the options. It worked fine for a while but I'm ready to trash it.
thanks for your suggestions
tarafından
yea that answer is really helpfull but it didnt work but thanks
tarafından
Great help, hard reset worked just fine for me. Thank u.
tarafından
Yorum Ekle
My visual land Prestige Elite will not go past the front page that states that. It freezes I tried to hard boot nothing I tried to reset nothing. Please give me more info on the subject.
Update (10/11/2015)
The android never comes up just the title visual land prestige Elite..
Puan 3
1 Yorum:
Mine is stuck on Prestige Elite screen. Please help
tarafından
Yorum Ekle
Thanks so much! I followed your advice which was more accurate than the guide that led me to this link. The only thing I would add is that I had to depress the power button while tapping the volume up button a second time after the Android robot with an exclamation point appeared in order to get the recovery menu to pop up. Still, it got me to a factory reset without having to replace the reset button. Also, my system storage space was used which is ridiculous since it only allows you 1Gb "Nandflash" & I had plenty of storage space available on both my 32 Gb SD card & had only used a few Gb of the supposed 16 Gb HD. After lengthy research, I determined that any items you install besides maybe photos & music gets stored directly into your measly 1Gb RAM (aka Nandflash) & only a tiny portion can be moved onto the SD card. Whoever designed this tablet must have decided that you would only use this tablet to take pix or store music so maybe that is why it is advertised as good for kids as it is sturdy & the charge lasts longer than some other tablets I purchased. It does not work for my child because she likes to play games. (I gave her the $250 IPOD Touch I won by completing a lengthy IT survey & she loves it.) My husband is OK with his Visual Land Prestige Pro 7D because he primarily uses to listen to music videos on you tube. I did find out that it may be possible to customize it but the instructions seemed cumbersome and risky & I did not wish to brick it. (It would be really great if Visual Land would offer the drivers for their Rockchip 4033 device but I am not holding my breath for that release) As such, I saved some $ until I could afford to buy a refurbished Samsung Galaxy android 4.1 tablet 16 Gb HD with 2 Gb RAM at twice the price from techforless. I am an IT specialist & everyone I asked recommended the Samsung Galaxy including the DELL repair technicians. I purchased the cheaper tablets with different android operating systems, JELLYBEAN & ICECREAM because I needed to learn how to support tablets for my job. I stayed away from KITKAT because the guiding rule of thumb in IT is to always avoid the latest release of anything until the manufacturer has worked out the bugs and it is fully supported by the software developers. The only other tablet that was reasonably priced that I really liked for games was the HKC P771 series but it's only 8Gb storage/ 1 Gb RAM and I killed the battery because of the 5 hour charge limit - it still runs hot (always has to be plugged in to the charger) Again at only $70, it's not as sturdy as the Visual Land but it used the SD card effectively and it was a pretty good starter tablet. I also killed a battery on a FileMate tablet on which I have yet to attempt any repair. My brother gave me a ViewSonic G Tablet which looks great & seems really sturdy but, like the Visual Land, has limited use because of the difficulty involved with installed apps. However, there appears to be a lot more forum support for it so I may try to customize the operating system. I hope this helps you which is why I included all the additional data. In closing, I wish you all good luck & please share your experiences - both good & bad - with the rest of us because trial by fire is very stressful & I wouldn't wish it on anyone.
Puan 2
Yorum Ekle
mine is stuck tuned off a not even the hard reset would work
Puan 2
2 Yorum:
mine is the elite 7Q
tarafından
My tablet dose not working it show only symbol please help me
tarafından
Yorum Ekle
I have problems with my tablet but thank you
Puan 1
Yorum Ekle
Omg!! Thank you for your help!! I couldn't use my tablet a whole year since it wasn't working. I tried the way you said and it works fine. Thank you
Puan 0
Yorum Ekle
Look up how to do hard reset on android device.
Puan 0
Yorum Ekle
My visual land froze how can I did orbit won't shut off!
Puan 0
2 Yorum:
What do I do when my visual land freezes up and won't shut off!
tarafından
What is the solution?
tarafından
Yorum Ekle
Yanıtını ekle
GALE SPRATT sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 9,951
