Ana içeriğe geç
Gateway makes quality notebooks, laptops, and netbooks. Owned by Acer Group.
gateway power on but screen stay black
power light come on but the screen stay black
Bu iyi bir soru mu?
Puan 20
12 Yorum
Does the pc give a series of beeps when you turn it on? If so how many beeps?
tarafından
no it does not beep
tarafından
Yes 2 beep when powered up
tarafından
Gateway lap top computer is on but the screen is black.
tarafından
Yes it comes on! The screen just stays black
tarafından
7 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
“Blank/Black Screen” on a Gateway Laptop
Ridiculous problem.
Simple fix.
This works 90% of the time.
Turn on Laptop. The tiny blue light means it’s on.
Top left corner of the keyboard.
The button next to “Esc”.
Labeled “LCD” - Better known as “F1”.
Press it.
All good?
I hope it was that simple.
I also hope someone at Gateway does the company a favor and removes that button.
Bu yanıt yardımcı oldu mu?
Puan 7
15 Yorum:
That worked for me. Thank you so much I can't believe it was that simple. Very appreciative ❤️
tarafından
I don't know whether to to kiss you or punch my laptop first. You're amazing! Thanks!
tarafından
It didn't work for me!!!, 🤨😭😒😠🤬
tarafından
Unfortunately, my F1 is a "Zzz" button. Still tried it, but nope.
tarafından
I was on my computer and than the screen went blank but shows it’s on so I’ve tried everything in the last 3 hours and it still hasn’t worked
tarafından
10 tane daha yorum göster
Yorum Ekle
3 possiblities:
1-bad ram module
2-remove ALL power supply to unit. Battery, power cord. Push and hold power button for 60 seconds. Try it now.
3-bad inverter board or backlight bulb.
Puan 4
2 Yorum:
One way or t'other, it did work. Thanks.
tarafından
Well i did the hold the power button down for 60 seconds and was counting to 60 but I only got to 8 when it started to power off then on again so now it’s on and I am going to the same website I went to when it went haywire the website is xfinity. Com but I don’t know if that was the problem
tarafından
Yorum Ekle
Take the memory out. Mine did the same thing.
Puan 3
2 Yorum:
Are you saying to replace it ? Or just take it out and try to start it?
tarafından
@kcitissues
The idea is to reseat the memory module(s) i.e. remove/replace, in case it is a faulty connection between the memory module and the motherboard preventing the laptop from passing POST.
Be sure to disconnect or remove the laptop's battery before removing/replacing the module(s) to avoid damaging them electrically.
tarafından
Yorum Ekle
I pressed the F1 and it did absolutely nothing. I still have a black screen.
Puan 0
1 Yorum:
@suejenkins exact model is your Gateway? what are the issues with it?
tarafından
Yorum Ekle
Engr. Says display IC is bad but no suitable replacement? What do I do?
Puan 0
Yorum Ekle
Yanıtını ekle
Ron Hill sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 43
Son 30 gün: 160
Her zaman: 52,419
