Ana içeriğe geç
Acer Iconia One 7, Nisan 2014'te piyasaya sürülen bir tablettir. Iconia One 7, medya eğlencesiyle dolu kompakt bir pakettir. Hem net hem de renkli, phablet'ten daha büyük bir ekranla, işlerinizi sürdürmeniz için hızlı tepki süresi ve saatlerce pil kullanım süresi elde edersiniz. Ayrıca, ebeveynlerin kontrol edebileceği birçok harika çocuk içeriği barındıran Kids Center platformumuzu da dahil ettik.
Acer Iconia One 7 Screen Digitizer Video Tutorial
Could you please make a Screen Digitizer replacement video Tutorial for Acer Iconia B1-730 ? is there any model that has similiar process of digitizer replacement and already published in your youtube channel ?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi There, I am looking for the exact same tutorial. Were you able to locate one?
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I haven't found one. So I tried myself the replacement seeing similar tutorials with great success. Now, the tablet is working again with a new digitizer, however I still have a problem with the screen calibration. The digitizer is working good, however when I point my finger on it, the command is recognized in a different position, some centimeters above from my finger position. Anybody knows how to fix it ?
Puan 0
5 Yorum:
Hi, Did you ever sort this - I am doing a repair and have the same issue! on two different digitizers!
tarafından
Nop. Problem still remains.
tarafından
I have decided that the digitizers sent are not 100% correct. They appear to fit perfectly but they do mask the edges of the lcd slightly. Tried a 3rd digitiser and still the same issue. I have a new tablet coming and will compare the digitiser measurments.
tarafından
Looks like the only available digitizers are not 100% the same size, The side borders are too wide so obscure some of the lcd and the heights are a bit thick too. Has anyone replaced a digitizer with a ebay special and it work ok?
tarafından
Hi Jon... the same happened here with my digitizer. The measures is not the same like the original one.
tarafından
Yorum Ekle
I want to repair my acer iconia tab 8 but i dont know where to found à new screen cam someone help m,e :( ?
Puan 0
Yorum Ekle
I wanna ask on what button should I select to organize my apps?? Thank you
Puan 0
Yorum Ekle
Yanıtını ekle
ricartengenheiro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 2,484
