Ana içeriğe geç
Released in November 2012, the GoPro HERO3 is a Wi-Fi capable, 4K resolution digital camcorder.
104 Soru Tümünü görüntüle
Charge point broken in Hero 3
Where the cable goes into charge, it looks like the pin connector inside the Hero 3 has broken off and missing.
I only noticed it after daughter has had it for past 6 months!
How do you replace it? Do you have to replace the motherboard?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Mark,
Go through this teardown, pull a picture showing the broken connector, and post it here.
If however, it is the mini-USB charging port like you described, you'll need to replace it using solid soldering skills, the right tools, and of course the right replacement part. No need to replace the whole board. My advice in this case, if you lack the pre-requisites, is to have a specialized tech handle the repair, or take it to a GoPro reseller and have a shot at warranty coverage.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Mark sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 876
