Ana içeriğe geç
Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
97 Soru Tümünü görüntüle
Battery replaced slide bar to unlock does not work
Ipod Touch 3rd gen - we replaced the battery. It charges quickly and completely. I restored it through my iTunes account via cable. Only problem is that I cannot slide the bar to unlock.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
The hold switch probably got misaligned when you put the iPod back together. You need to open it again, and move the hold switch on the back panel into the same position as the little black switch on the logic board, and put it back together like that. Then, when you move the hold switch, it should work.
Also, before putting it back together, you can turn on the iPod and make sure that the little black switch on the logic board works.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
bnailchi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 61
