Ana içeriğe geç
The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
still soft brakes after bleeding them
I changed my 1994 Ford Ranger rear brakes bleed 3 times and adjusted them still soft peddle (goes to floor) while driving please help what do I do next
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Assuming the bleeding procedure was done correctly, did you check for leaking lines, bad bleeder nipples or leaking wheel cylinder? If all of those are checking out, you need to consider a bad master brake cylinder.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
OK ty has to be bad master cylinder again ty
tarafından
Make sure if it has RABS you're bleeding the abs unit on the frame rail!
tarafından
Yorum Ekle
Did you try putting a piece of wood under the pedal while bleeding ,...? I've heard it was nessesary on that year Ranger
Puan 0
Yorum Ekle
Yanıtını ekle
Jerry buddman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 1,400
