Ana içeriğe geç
The Xiaomi Mi 3 is a high-end, premium Android smartphone that is produced by Xiaomi.
Any tips for replacing the charging port?
I want to replace the charging port as it is broken. Please help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
4 Yorum
Hi Gaurav, I just want to ask, when you replaced the charging dock where there any components on it that you had to solder? Or was it a simple screw/unscrew replacement.
Thanks a lot!
tarafından
Just un screw and replace a riblon that is gently glued
tarafından
Hi Marcel, thank you so much for your assistance. One last question I promise and forgive my ignorance in the topic. Regarding the Xiomi mi3 charging docks, it seems that there are two options.
1)One with a mic on it (http://www.aliexpress.com/snapshot/68262...)
2)One without (http://www.ebay.com/itm/231518898672)
Not sure which I needed I ended up ordering both. Is the mic soldered? Which one should I use?
tarafından
I want replace charging pot.I need open whole phone?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Please check out the touch screen replacement manual as far as the usb ribbon is changed.
You may change it without the motherboard remove Step. So from Step 5 go directly to Step 9... It is easy.
You will find replacement part on aliexpress site.
Bu yanıt yardımcı oldu mu?
Puan 4
3 Yorum:
Hi I have the exact same problem where is this manual you are referring to? Could be kind enough to post me a link? Cheers
tarafından
Thank you! It worked perfectly.
tarafından
Yorum Ekle
Hi I have same problem
I was ordered this part 2 time from eBay but after replacing it.
No service
There is reception problem please guide me from which place original part will available
Puan 1
1 Yorum:
Hi Guarav Narang Sir
Please help me about replacing this part
tarafından
Yorum Ekle
Yanıtını ekle
Gaurav sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 8,441
