Ana içeriğe geç
24 inç ekran; dahili iSight Kamera, mikrofon ve hoparlörler; 1920x1200 çözünürlük. Ekim 2008'de piyasaya sürülmüştür, A1267 model numarasıyla tanımlanır.
Flickering band running down display
I have a band about 1 inch wide going down the right side of my Apple flat panel monitor. It looks like very thin white lines constantly flickering on the screen. Is this indicative of a bad DVI cable or a problem with the screen itself? Any information would be helpful.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I Have seen this in my brother's laptop, some forums say it is a display panel issue, others say it is a video-ram issue, try hooking up annother display, if it does the same, your computers graphics card is bad, also, which apple display, is it a Studio Display (3 Legged Picture frame like thing with powermac G4's and early G5's) or is it a Cinima Display (Newer Aluminum Displays Matching The PowerMac G5 and Mac Pro) or is it a LED Cinima Display( newer LED Backlight with a Mini-Displayport connector for MacBooks and Mac Mini's)?
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Oops, if it's external, than it won't be the video card causing the problem. I thought it was a MacBook display. Anyway, it seems like you have a bad panel.
tarafından
Yorum Ekle
Try with a different DVI cable and different input computers to see if it is the screen. If it works with a different cable/computer then the display is fine. If the problem remains the display is broke and I think when that happens you need a new one.
Someone correct me if there is a way of repairing a LCD
Puan 0
Yorum Ekle
the dvi cable is built into your monitor, so its hard to replace that... could be a bad pin on it or a bad inverter assembly inside. theres not much you can do to fix it without some specialized apple or lcd repair shop that deals in re cabling the screens
Puan 0
Yorum Ekle
Have you tried attaching your display to another computer to see if the trouble still occurs?
If it doesn't you have a display driver/hardware issue that you need to address.
If it does, you are in some trouble. With a built-in cable, all you might be able to do yourself is open the monitor up and see if the connection is good on the monitor side, and reattach as necessary.
Puan 0
Yorum Ekle
does anybody know the serial number ?
Puan 0
Yorum Ekle
Yanıtını ekle
Dash sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 7,286
