Turn table plate does not spin or rotates
My counter top ge microwave turn table does not spin or rotate even there is power and the timer and light is working.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Please give us a model number to find parts.
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Bu yanıt yardımcı oldu mu?
How do I check the turntable motor?
what is your model number?
I have similar problem. GE model PVM9179SK1SS. How do I test the turntable motor?
I have the same problem turntable does not turn.
GE model is JVM6172SK3SS
Serial SM218722B
Manu. Septiembre 2019
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 8,139
