How do I fix the sound on my phone?
The media and all the ringers are all not working even though it says it isn't on silent. When I plug in the headphones, then it works and its the only way I can watch videos.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
it seems to be your main speaker (Ringer) faulty. you may have to replace it
Bu yanıt yardımcı oldu mu?
How do I do that ?
you can get an idea how to teardown it
did you ever figure it out???
I replaced my speaker and it still isn't working what can I do now
Backup all data and reset the phone. check whether speaker back to working condition, otherwise you have to check audio out/ amp section carefully
Turn Bluetooth on and off
Worked like a charm thanks bud
Was having same issue.. Came here for answers...saw a thread that said turn Bluetooth on and back off....worked for me...
Thank you I'll try that
Wirked like a charm wow
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 50
Her zaman: 199,939
23 Yorum
My speaker is not working how do I do it if u got urs to work...please... Thanks a bunch
floressusanne tarafından
I'm having the same problem. Did you ever get it fixed
Loka tarafından
I got the same problem
Tyliah Carter tarafından
I had to install an app called SoundAbout from playstore.
Walter Montgomery tarafından
When I make call people on other end can hear me but I can't hear them, volume is all the way up and when I get call it only vibrates
superdave446 tarafından
18 tane daha yorum göster
