Ana içeriğe geç
2012 yılında piyasaya sürülen Toshiba Satellite C850, AMD veya Intel işlemci seçeneğiyle sunulan 15,6 inçlik bir dizüstü bilgisayardır. USB 3.0 girişine sahip olan bu model, depolama için 1 TB'a kadar HDD ve harici grafik kartı ile yapılandırılabilir.
Restore to FActory setting software
I have been trying to restore my Satellite C850-F211, but it doesnt seem to complete. Its like there are 47 steps to complete but its stuck on 27/47 and for more than 6hours, it displayed 'Setup is preparing your computer for first use'..https://drive.google.com/folderview?id=0...
Bu iyi bir soru mu?
Puan 1
1 Yorum
On a C850, you go Windows key/Restart,..hold the Shift key as you click restart & keep holding until you see the reset option screen
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
First of all, remove the picture with the Windows product key!
Not a problem if you turn off and on the computer (restart) because this is the finale phase. The installation will continue from the last completed step.
It is likely, have a problem with the hard drive. If the problem persists, test the hard disk for bad sectors.
If there is problem with installation, you can start recovery process again like this - press and hold 0 (zero) key and then switch on the laptop, it will start with the Toshiba HDD Recovery Utility screen or you can select HDD Recovery from the boot menu (F12).
Regards.
Bu yanıt yardımcı oldu mu?
Puan 1
5 Yorum:
Thank you, this has really helped me. I am yet to test my hard disk for bad sectors. I might end up having to replace it. How long is the life span of the harddisk? 3years..
And what are the best practices to prolong life of a HDD:
1.Does switching your laptop off when not in use one of them...i keep my laptop running sometimes for the whole week..
tarafından
Hard disk is a mechanical part (the disk is spinning with 5400, 7200, 10000 rpm). This is the main reason for the problems.
My advice is not good practice but good choice. Some manufacturers provide more guarantee of its products.
This is one good article about the HDD problems:
http://www.extremetech.com/computing/170...
P.S. The best thing to do is keep a back up!
tarafından
Hello , my laptop is a Toshiba Satellite C850. It shows me a black screen with a lot of info written there but the last two sentences are write PXE-MOF:Exiting PXE Rom. REBOOT and Select proper Boot device or Insert Boot Media in selected Boot device and press a key ._
May I ask what should I do?
Please get back to me on my email (nhshelembe@gmail.com )or here
Thank you
tarafından
Hello I have had the same problem it is to do with the hard drive so you need to go to a shop and they will repair it for you it cost me a total of £60-70
tarafından
Hi there, I restarted my laptop configuration and it took like 1hr to finish and now it’s just turn on and off like crazy how do I reset that ? Please help it won’t allow me to use the method zero and power key. HELPPPP HELPPPP!!!!!
tarafından
Yorum Ekle
Yanıtını ekle
Pako Mere sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 14,147
