Ana içeriğe geç
Lenovo ThinkPad T500. Temmuz 2008'de tanıtılan bir iş dizüstü bilgisayarıdır. Bu 15,4 inçlik dizüstü bilgisayar, 2,26 GHz Intel Core 2 Duo P8400 işlemciden 2,8 GHz Intel Core 2 Duo T9600 (veya 3,06 GHz Core 2 Extreme) gibi üst düzey işlemcilere ve Intel tümleşik veya ATI değiştirilebilir grafik kartı seçeneklerine kadar yapılandırılabilir.
Why is my computer getting so warm?
After 30 minutes of use, the laptop is very warm on the bottom and is uncomfortable to have on my lap. What's going on?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
There could be several reasons your laptop is getting hot. First off, laptop is a bit of a misnomer--they get hot and are meant to be used on a desk. Secondly, this laptop is a good 7 years old at this point, when was the last time (if ever) it had a thorough cleaning done on it?
Start with the basics and clean it out, new thermal paste, etc. Then if you are still experiencing abnormal heat issues (ie, burning your flesh), then there are some other issues at play here. If it is heating up after 30 minutes, though, probably needs a good cleaning.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Use your laptop on a Hard surface so the fans and case can dissipate the heat the right way. If you use it on your lap you have your body heat + the laptop heat, which will make it hotter.
http://gadgetwise.blogs.nytimes.com/2009...
Puan 0
Yorum Ekle
Hi! You may have a problem with your fan. Try to clean your fan with a compressed air can.
If the problem persists, take a look at the Troubleshooting page to diagnose your exact problem.
Lenovo ThinkPad T500 Troubleshooting
Puan 0
Yorum Ekle
its probably because u are not cleaning our laptop at all. or even trying to clean most of it.
Puan 0
1 Yorum:
Does like opening the laptop and cleaning some dust with air blower and stuff help run the laptop smoother?
tarafından
Yorum Ekle
Yanıtını ekle
Nickie Gurney sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 7,194
