Ana içeriğe geç
Mid 2013 revision to the Xbox 360 line of game consoles, featuring 4 USB ports and built-in Wi-Fi connectivity.
89 Soru Tümünü görüntüle
It is possible to just replace fan
My son has a x box 360E the cooling fan is making noise, and will prevent the console from being used. Is it possible to just replacement the fan? Do we HAVE to buy special tools to make the change, or are we able to use small screw drivers and tools non specific to x box?
Bu iyi bir soru mu?
Puan 2
1 Yorum
yes you can replace it
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
aloram85, you will need a T6,T9, and T10 screwdriver. Use this guide to get to the fan.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I would not just replace the fan as it is often a problem with fan-cooled-devices that it is running too fast, because of dust sitting in the heat sink or new thermal grease needs to be applied onto the cpu of the xbox. There are many videos on youtube how to do this! Such as this one:
https://www.youtube.com/watch?v=nFc7imbB...
In my case it already helped to use a high pressure spray by spraying into the fan of the xbox. So probably it wasn't a thermal-grease-problem ;)
tarafından
Yorum Ekle
Yanıtını ekle
aloram85 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 31
Her zaman: 4,638
