Why isn't my bike shifting?
When I shift through my gears it won't switch to every gear. Sometimes it skips a gear or won't shift at all.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Your shifting troubles is likely caused by your derailleurs. Dmadro's explanation is correct, but if you are unsure how to make these adjustments, you can take a look at one of the guides explaining each step on adjusting the front derailleur and rear derailleur.
Kılavuz
Zorluk:
Çok kolay
10 - 20 minutes
Kılavuz
Zorluk:
Kolay
10 - 20 minutes
Bu yanıt yardımcı oldu mu?
Check the shifter cable. There is an adjustment at the rear derailleur that you can turn to loosen or tighten the cable tension. Put the chain on the smallest gear on the rear wheel. Shift up to the next gear. If the shift does not happen, turn the cable adjuster to tighten the tension on the cable. If you shift and the chain moves up two gears, loosen the cable. Park Tools is a good website for this sort of adjustment.
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 7,166
