Ana içeriğe geç
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Soru Tümünü görüntüle
Why does it keep on restarting?
When I shut down my system, it keeps on restarting.
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
6 Cevap
Filtre ölçütü:
Seçilen Çözüm
Could be a permissions issue.
Insert your OSX install dvd and hold option on startup or when it restarts.
You will have the option to boot from HDD or DVD choose DVD.
Once it loads (may take a few minutes) select disk utility.
*You may have to select a language or something.
In disk utility select you HDD and then you can "check disk permissions" and "repair disk permissions".
This may be the reason it keeps restarting when you shut it down.
It also could be a pending install of an update that is corrupt, but this should correct that issue.
If not let us know.
Good Luck!
-Varsity
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Would a Mac OS permissions issue make it happen in Windows also?
tarafından
If its running windows through boot camp yes its possible, but windows itself is a whole other issue lol.
tarafından
Yorum Ekle
En Yararlı Yanıt
Have you tried to shut it fully down by holding the power button down till it goes off (forced shut off?)
That should keep it off - and maybe it behaves after you start it up afterwards - give it a shot
Puan 2
2 Yorum:
that would be my first try!
tarafından
Yes, only like that it would be turned off, but it doesn't matter in windows or mac os, when I choose shut down, it restarts itself, it is the First time that I'm facing such a problem.
tarafından
Yorum Ekle
Try typing in the command-line:
sudo shutdown -h now
Sounds like a permissions problem though.
Puan 0
Yorum Ekle
Could it be a battery issue?
May be a battery calibration will help.
Puan 0
Yorum Ekle
I've just started having this problem on my MacBook. Did you ever figure out what was causing your problem?
Puan 0
1 Yorum:
I would try resetting the SMC. Heres a TN on how to do it: http://support.apple.com/kb/HT3964
tarafından
Yorum Ekle
ive been having the same problem with my MBP. I recently did some troubleshooting by replacing the hard drive with one from a full functional MBP. Even with the new hard drive, my macbook would still restart everytime. Thus proving that the issue is not software related. I'm stumped.
Puan 0
Yorum Ekle
Yanıtını ekle
MEYSSAM sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 6,220
