Ana içeriğe geç
High-end gaming laptops produced by Alienware (a subsidiary of Dell since 2006).
Why is my alienware M17X display flickering
Hello,
I have a M17X laptop from late 2013. My display is flickering when moved in different orientations. Initially i thought it was a screen issue so i disconnected the power and display connection to the screen. After cleaning and reseating the issue still occurred. Could it be a loose or defective cable in the screen or could it be a issue with the video card?
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes . you are correct, fault con be coming from Video card, LCD cable and LCD as well
Trace it,
  • Check the graphic configuration set it to default level and see whats going on if same fault observed,
  • Connect you M17X to external Display and check any sign of flickering
if yes - fault coming from your Graphic chip
if no - you can determined LCD or Display cable make the trouble and both of coming together and you can the Display with cable
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Buddhika,
Thank you for the confirmation. I had re assembled the LCD and remounted it to confirm the fix was not GPU related.
Thank you,
Phil
tarafından
Yorum Ekle
Yanıtını ekle
psortino2007 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 7,133
