Ana içeriğe geç
Screen Black but Camera Still Shoots-Help!
One day my Cannon Rebel T3i was working great! The next day, the screen went black yet the camera still took pictures that I was able to download. I am unable to replay pics or view which setting I am in on the screen. The menu or info buttons are not working either. I have tried several troubleshooting ideas from the display button, removing and recharging the battery, replacing the SD card, to pushing the info button several times to reset the screen yet nothing seems to work. Any other suggestions would be greatly appreciated! Thanks!!!!!!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
I had the same issue with my camera
I finally found solution ... today when i was cleaning my dslr i removed fully and re fixed everything all of sudden no images not display except dark black screen ... i was wondering if i have forgot to plug in something inside my camera.. Finally i found that the connection between Display screen and the chip set was dismantled i prayed for god then connected it back finally when i turned it ON ... Boom ... that was my solution
may by some case or something like that it might be disconnected or u might change the Screen or circuit
tarafından
Display not working canon 200d camera power on but is camera not display
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I have read that trying to push the rubber eyepiece protector down firmly as I read that if it is up slightly, it can cause the screen to go black. No luck for me!
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Hello, I had this problem last night, visited this forum, but to no avail. However…. I did discover a fix….
I was using an intervalometer and it was inserted into the camera a little to far. When I removed it everything worked as normal. I reinserted the intervalometer, with a bit more prudence, and it has been working perfectly ever since.
Puan 0
Yorum Ekle
I encountered the same issue on my Canon eos 1500d
the display was off.
it turns only when we switch it to Video mode(but was not able to record in video mode)
Camera flash automatically pops up tooks photos.
Solution :
  • I have removed the Card from camera and formated ( this is not needed by the way)
  • charged the battery to full
  • dont remove the cameras lens cap
  • put the camera to manual mode
  • Take a photo
  • then after 1 or 2 second click on any button ( delete/preview..etc )
this turned my display on and there is no issue till now.
if this doesnt works in the first try
tey again next day
Puan 0
2 Yorum:
I also encounter with this situation. Can you help me please🙏🙏
tarafından
Hello,goodmorning. I have a problem with my canon camera eos 2000. The screen display is blank. Powering is ok and it shoot on blank screen. Sometimes you power on and it displays and dissappears. Sd card i bought yesterday and needed to update camera but cant display. I need help.
tarafından
Yorum Ekle
Yanıtını ekle
Tami Lynn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 58
Her zaman: 21,735
