Ana içeriğe geç
The 6th generation (E90) of Toyota's best-selling compact car. Also sold as the E90 Sprinter, Holden Nova, and Geo Prizm. This generation was the last of the Corollas to be classified as a subcompact vehicle and the first exclusively front-wheel drive or all-wheel drive Corolla (the rear-wheel-drive option was dropped for this generation).
15 Soru Tümünü görüntüle
Soru Kapandı
remove heating fan and casing from under dash
how do I remove heater fan and case from under dash on 1992 Toyota corolla
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First of all, you have to open the glovebox, then empty it and press the walls of the glovebox (left and right wall) to the center (you have to bend them a little, it will only be temporary.
Now you can turn the glovebox down. You will see two Phillips screws. Remove both.
The glovebox is now removed. The heater fan is now accesible. just remove the clip and the screws and the cable.
install the new one and do not forget one of these steps backwards.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 577
