Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
Brand new iPhone took a swim.. Advice?
So Saturday morning I decided to let my brand new iPhone 6 take a refreshing dunk into my toilet bowl where it sat for about 4 seconds.. I immediately removed my cheapy case and tried to power it down, but as soon as I pressed the power button the screen lit up on the lock screen, it then proceeded to freak the heck out and then shut off completely. After punching myself several times, I wiped it off and set it in the window to dry for about an hour. After that I got my tool kit and took the screen off to expose the hardware and let it dry like that until Sunday evening, I put it all back together and plugged it in to which I got no reaction. The phone would not power on at all. When putting the screen back on, I think I identified where the short took place in one of the snap connections between the screen and the phone. So my question to the community is: Can it be saved by replacing the screen, battery or some internal component? Looking for positive feedback, please. I'm already bummed out about this whole thing.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There are several options and a few ways you can approach that:
From a technican view I say: If your waterdamage is fresh (no longer than 1 Week) it can almost ever been saved. Time is the most important thing when it comes to water.
1) bring it to a shop that are known to deal with waterdamaged phone (sadly many provide that service but few know what they are doing) who can clean it professionally
-> this involves removing the EMI Shields (they are soldered to the logicboard) and a ultrasonic cleaning with sweeping frequenzy and a manual cleaning corroded spots
then they need to figure out what parts needs to be replaced (hardest part) and of course replace them. Every waterdamage repair should come with a battery replacement.
If they do this properly, you can be happy for many years with that phone.
To answear your question: YES it can be saved by replacing what beeing damaged, but without a poper cleaning your phone will give in. In a few weeks or at most a few months (depends how wet your board got)At this point parts of the logic board are corroded and the water has eaten solderconnection that seldom can be replaced (meaning your phone has no value anymore)
Since you have an iphone 6 (nice phone) i would go with option 1)
IF You want to deal with it yourself:
You can use a soldering iron to remove the emi shields, do that and soak the board in a container with 99% isopropyl alcohol and cleaning it gently and very very very VERY thoroughly.
Now replace those burned/shorted components (you cant do it without hot tweezers or a reworkstation)
another quick clean
and let it dry for 2 days
give it a try.
To be clear, chances are if you not a experienced micro solderer, you might do more harm than good. I do not want to discourage you but this is a matter of equitment :-)
hope it helped somewhat.
Good luck Sir
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Amazing advice sir! I will definatly try option 1. Only hard part is I am an American stationed in Germany and I don't have the slightest clue where to find a cell phone repair store that specializes in water damage. I will look though! Thank you!
tarafından
Yorum Ekle
Yanıtını ekle
Logan Barbee sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 198
