Where is the speed sensor?
My 1992 3/4 ton truck 4 wheel drive is throwing a code, 24 speed sensor failure, where do I find this sensor?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
8 Ball it should be located on the transfer case output shaft.
Bu yanıt yardımcı oldu mu?
It should be located on the driver side of the transmission near the rear where the transfer case meets but on some of them it is on the passenger side.
I do not have 4 wheel drive.
At the rear of your transmission on the transfer case just where your drive shaft slides in
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 128
Her zaman: 37,828
1 Yorum
I have a 1995 chevy 4by4 and the speedometer isn't work and it's not shifting into 3rd gear could it be a sensor
Sheila Skorcz tarafından
