Ana içeriğe geç
HTC One (kod adı M7), HTC'nin 2013 yılı amiral gemisi telefonudur. Kusursuz tasarlanmış yekpare alüminyum gövdeye, ön tarafta 2 adet büyük hoparlöre ve 4.7 inç 1080p ekrana sahiptir.
Red led is not on and not turn on
Hello, my problem is that the phone does not turn on.
I was using the phone with low battery, I tried to connect it to the socket but it did not get charge. The red led was off and the icon of battery did not change. When the indicator had 0% the phone turned off and never works again.
I replaced the usb connector multiple times after that but when I connect to the socket the red led does not appears.
After that, I charged the battery with a external charger, but the phone did not turn on.
Is the remplace of the motherboard the only solution?
Thank you!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
you could solve the problem? Please help-me!
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
1) Check any sign of burn makes of Capacitors around PM ic - If yes : Replace them
2) Replace new PM ic and check
**BGA reworks skills required
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Victor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 244
