replacing the serpentine belt
how do I replace serpentine belt on my 1997 ford expedition XLT 5.4 liter engine?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Find the tensioner pulley, (usually labeled on a diagram on the radiator shroud) using a 1/2 ratchet loosen the tension on the belt to remove from pulleys then feed over cooling fan blades, install in reverse order placing belt over all pulleys then loosen the tension off tensioner pulley to slip over it and release to tighten.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 2,533
