Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
3.6 mm Pentalobe screw is stripped
it appears one of the two 3.6 mm Pentalobe screws is stripped, what now?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Stripped heads or stripped threads? ie. does it just turn around and around, or can you not get a screwdriver in there?
If it's stripped head:
1. Get a left hand drill bit. Machinists use these all the time to back out stuck screws. Use it in a drill set to SLOW speed.
2. You can get a product called screwgrab that's a friction gel that helps drivers get a hold of the screws. Works better with phillips screws though.
3. You can glue a bit in there. Use superglue, or even better epoxy. Let it set up. Then back the screw out.
4. Take the iphone and set it on something that vibrates. I've used the top of the washing machine and ran a couple of cycles. The vibrating will work screws loose. The only thing to remember is to check ALL the screws afterwards.
If it's stripped threads you should be able to remove the back anyway. The backs have tabs that the screws go in. They do strip fairly easily, and sometimes they actually get disconnected from the back or crack. So just push the back up and pop it off, then the screws will fall out. To replace you can either replace the back with one from here or use superglue or threadlocker on the threads of the screws when you replace.
Replacement rear panel compatible with iPhone 4S. Perfect fix for any cracked, scuffed, broken, or shattered back glass. Compatible with all iPhone 4S models. Available in black and white. This is a blank panel with no logo. Görseli
Ürün
iPhone 4S Blank Rear Glass Panel
$19.99
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Use a dremel and cut a slot in the top of the screw. Then use a flat-head screwdriver to take out the screw. Otherwise a drill with a small bit should help get it off.
Puan 1
Yorum Ekle
Yanıtını ekle
bamaaeiou sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,119
